saw a r33 gtr with the plates yun1 or jun1 on milperra rd today also a lime green r33 gtst on parra rd and a grey 34 gtr turning onto parra rd near fraser motorbikes
Cool I've been spotted action-smiley-069.gif Grey r34 gtr. Think that's me if it was around 2pm
Spotted you, DC33VN, Tuesday afternoon on the way home from picking up my new car. I was the one behind you in the black R32 GTST at......some point haha. Not too familiar with Sydney area.
Great car, man :).
Edit
...Assuming you are SHY-26L, anyway...
Edited by Charlesy006
wohoooo I finally got spotted haha :D, i spotted a white r34 gtr plates shy26l at rockdale today again next to charcoal kingdom.
Finally one of my random skyline photos is actually someone on the forum, brings a warm interconnected feeling to the cockles of my heart, or maybe the sub cockles..etc
wonder if this guy is also a member?
in city just after xmas, either way its a sweet GTR
Ok, big day today spotting Skylines.
-Pull out of my street in Robertson to head down to Shellharbour and saw a purple R34 and a chracol R32 cruising together. Thumbs ups were delivered and returned.
Hope you gentlemen had a good punt up the pass.
-Parked near a silver R33 S1.5 in Shellharbour.
-A gold R33 in Shellharbour.
-White R33 number plate SCREAMR or something similar in Albion park..
-Red R34 headed southbound going through Albion park.
Black R32 GTR with a Nismo badge and all the gauges in the universe - Grosvenor St Lindfield turning on to Lady Game Drive. Looks mean and left rear hand side FILTHY from what I imagine is good boost mate!
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
