Chris I'm getting Nepean Smash Repairs out at Emu Plains to redo my front bar. Terry recommended him after I hand a ding in my rear quarter. He knows how to mix midnight purple perfectly.
104 Russell Street
Emu Plains NSW 2750
(02) 4735 3522
Might be a bit of a trek for you from Wollongong but I don't know of anywhere else in Wollongong where you could go.
Cheers,
I just ended up taking it up to Bodyform today.
It's a decent drive but with his rep I'm confident it will turn out good.
I was just too worried some one down here would butcher it
Spotted Jennie's white R34 at work this morning.
They look great next to each other! :-) Wont need to check my passanger door for dents today either. Haha have a great day!!
For that exact reason, it's great when you get to park next to someone you know :)
That's right! Some people aren't as careful as others with their car. I am always careful not only so I don't hit another car but also so I don't damage my own! With a GTR next to me I don't need to worry. :-)
Waved to a silver S2 R33 in Albion Park today.
Not sure if wave returned, was checking for SAU stickers.
Near croome rd? Caught me off guard but i gave a nod... Ch'ur bro style.
My cars been playing funny buggers lately but I had intentions on going on last pizza cruise but carputer said no. Whens the next one?
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
