Dude the 32 in st Clair is nice I hate the kit tho !
He drives it like a grandmas car but at the track he is pumping 300+kW at the wheel
really? it looks like ass haha the wheels and kit are a sin, impressive if it does really have that power but
Saw a black R34 GTT with black wheels at St Marys station just then I think the plates were BNQ-03Q. I was in my mums silver Camry right next to you
That was me! waiting to pick up the mrs. lol first time spotted :D
Woo! I've seen you before sometime last year on the Gt Western but that was before I got my Skyline. I remembered the black on black
Just saw Ricky(LL00LL) passing me while I was parked at Tangerine St, Fairfield East.
Flashed my high beam, saw your hazard light. You've got the High JUN stands now like me. Real niiice in all black!
Had a nice chat with Terry whilst admiring the GTR at the Charity Car show in Springwood. Was nce to meet you. Your car is stupidly nice.
You're very kind Liam. Hope you had a great day! I rolled up at about 11 thinking that all the tarmac spots would surely be taken. Our family only wished to stay for a couple of hours because Maria was on an extended test drive of a new car on the same day. Plus we bought it. So the Cameron Burke Show was only an afterthought. Great meeting with you!
  • Like 2
When will it be mine turn to own such a beautiful creation.
A little off-topic, but do you have any other pictures of this on these forums, or just in general?
I've only been privileged to see 2 or 3 photos of your car, and unfortunately they've all been of the same angle/point of view.
Thank you for your appreciation :)
I still go out to the garage at times to think how lucky I've been.
This N1 has been shown before in...
SAU > Photography > R34s
And if you require hi-res, email me on...
[email protected]
Regards
Spotted the same HR31 Coupe [YRB20T] but driving. Had a quick chat to the bloke at a set of lights.
I'm guessing he works right opposite where I see his car parked all the time, either at the smash repairers or tyre place on the other side of that T-junction.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
