  On 29/05/2014 at 7:35 AM, barnoon said:
wtf ? clearly i was talking about him spotting me not racing
anyway spotted a maroon 32 gtst in st clair today with chromies and also a white 34 sedan on the highway in blaxland around 3pm
Last message in reply with ^
  On 29/05/2014 at 8:00 AM, troyaustinperry said:
Dude the 32 in st Clair is nice I hate the kit tho !
He drives it like a grandmas car but at the track he is pumping 300+kW at the wheel
really? it looks like ass haha the wheels and kit are a sin, impressive if it does really have that power but
  On 03/06/2014 at 9:07 AM, vinceyboy28 said:
Saw a black R34 GTT with black wheels at St Marys station just then I think the plates were BNQ-03Q. I was in my mums silver Camry right next to you
That was me! waiting to pick up the mrs. lol first time spotted :D
Woo! I've seen you before sometime last year on the Gt Western but that was before I got my Skyline. I remembered the black on black
Just saw Ricky(LL00LL) passing me while I was parked at Tangerine St, Fairfield East.
Flashed my high beam, saw your hazard light. You've got the High JUN stands now like me. Real niiice in all black!
  On 08/06/2014 at 1:59 AM, FordyR31 said:
Had a nice chat with Terry whilst admiring the GTR at the Charity Car show in Springwood. Was nce to meet you. Your car is stupidly nice.
You're very kind Liam. Hope you had a great day! I rolled up at about 11 thinking that all the tarmac spots would surely be taken. Our family only wished to stay for a couple of hours because Maria was on an extended test drive of a new car on the same day. Plus we bought it. So the Cameron Burke Show was only an afterthought. Great meeting with you!
  • Like 2
When will it be mine turn to own such a beautiful creation.
A little off-topic, but do you have any other pictures of this on these forums, or just in general?
I've only been privileged to see 2 or 3 photos of your car, and unfortunately they've all been of the same angle/point of view.
Thank you for your appreciation :)
I still go out to the garage at times to think how lucky I've been.
This N1 has been shown before in...
SAU > Photography > R34s
And if you require hi-res, email me on...
info@hope-health-group.com
Regards
  On 13/06/2014 at 8:23 AM, FordyR31 said:
Spotted the same HR31 Coupe [YRB20T] but driving. Had a quick chat to the bloke at a set of lights.
I'm guessing he works right opposite where I see his car parked all the time, either at the smash repairers or tyre place on the other side of that T-junction.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
