hey i was at drift day......at oran park...
i didnt see niether moanie or 321 go....
only skylines i saw was this black 33 with carbon bonnet and apexi decal on front mount a purple one with white rims...white gtt and me and mah friends black gtts.
anyways spotted msp25t at the workshop again today.....and the other day saw morgs car as well dark green 32 right ?
whats with your cars ?? hehe....you guys should start paying josh rent....  :jk:
anything wrong or just getting mods ?
OOO!!!!!!! which GTT were you? I saw you then :P cause two guys moved two black gtts from the main carpark into the carpark closer to the track!!! That was just as we were paying for our tickets :D
The purple 33 is HOT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! hmm...i love that colour! :(
How come you're at the workshop so often!!! hehehe..and yeah... i should pay josh rent!!!!
yeah im pretty sure it is....people at advan say it is...(of course they would !)..
and i heard that aluminium is not acceptable...and gotta be plastic...carbon fibre is close enough...hehe......like i said its a bit pricey...like $600ish from memory...
but hey its REAL CF..
hehe yeah my baby was one of them two black ones......the one with the high rear wing....and cwest kit.
oh!!  hahahahahaha.... well thats ok then :P  and it is cute! :D
Ahh!  nice :)  Do you get any freebies? :(
I don't still have the defect..i got defected for the second time :(  in front of harrys!!! *cry* and for the same things! :(  So i'll use the stock box i used the first time to pass the defect...but i want a permanant solution... i don't really want to go through all this again :(
OK :)
e-boost going in this week (profec B out). had to get rid of HKS SSQ (but t/smart one is seriously better!) mmmmm, freeebies.
I'm with the defect scenario now! Permanent sol would be V nice and more than likely lower your intake temps also. Maybe check the box that shonen was talking about at ADVAN. I'm going to see Peter at ADVAN 2moz anyways. I'll check it out for you if you like??
OO!!! The one with the c-west kit!!! yummy!!! that was definitely the more eye catching of the two :D I think another cruise is in order so i can check out all these hot cars in more detail!!!!!!!
Andrew - If you could, that'd be great!!!!! Can you ask them how legal it is? I seem to attract the epa/rta setups, and the box has to be legal enough for them to let me go without any problems! I don't want to get done again...especially not after paying $600!!!! : I keep planning on stopping off at advan...hehehe...but i've never made it!
Hmm...i'm assuming e-boost is a boost controller :P I've got profec a...hehe...i have no issues with it :( And i have no idea what a HKS SSQ is?
hehe HKS SSQ is a hks blow off valve...the ones that make them annoying whistling noises....hehe.....not a big fan...but after driving my friends car which has one...dont mind it as much...
hehe yeah im up for a cruise...im actually trying to get a group of black 34s...
already got 3....hopefully i can get some more !!
Sometimes I think this thing is plotting against me....
Now its in pieces all over the garage floor (mine, not Joshs this time!)... have I got the upper hand?
i know that feeling!! plotting to get bigger and better :)
how come the cars in pieces? what are you up to!!! :)
hehehe....i'll laugh with you cause hopefully you won't be replacing anything morgs :D
craved - yeap!!! definitely a cruise coming up!! its been ages since the last one!!! keep your eyes on the events thread :(
as for the idle prob...dunno what the prob is...its very erratic! will let you know once we figure it out :( And what were you doing to your car, that you had to put it back together?! :(
and where have you been in the mornings! i haven't seen you drive by in ages!!!! :)
craved - yeap!!!  definitely a cruise coming up!!  its been ages since the last one!!!  keep your eyes on the events thread :D
yeah i'm finishing early this month, leave at 7:30am! Will keep that eye out!
I had an overheating problem, turned out i had to replace the thermostat on the weekend, plus i have heaps of stress cracks in the end tanks of the radiator so time to save up for a custom alloy one!
but still got a similar idle issue, i've got down to possible TPS or O2 sensor issues. been playing around with it for weeks now! nearly got my dash finished now too - been making adjustments to make my guages legal - same defect issues as you've been getting!
spotted on Good Friday at the beginning of the Blue Mtns (Glenbrook area I think??)...black R33 pulled over on the side of the road - cop car behind it with it's lights on :)
hope whoever you are, you didn't get reamed with double demerits :Oops:
also, same day, a red MR2 (i thought of you Tosh!) ...dunno were i was but I remember seeing a Tommys Kebabs just down the road...
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
