OO!!!  The one with the c-west kit!!!  yummy!!!  that was definitely the more eye catching of the two :D  I think another cruise is in order so i can check out all these hot cars in more detail!!!!!!!
Andrew - If you could, that'd be great!!!!!  Can you ask them how legal it is? I seem to attract the epa/rta setups, and the box has to be legal enough for them to let me go without any problems!  I don't want to get done again...especially not after paying $600!!!! :  I keep planning on stopping off at advan...hehehe...but i've never made it!
Hmm...i'm assuming e-boost is a boost controller :)  I've got profec a...hehe...i have no issues with it :(  And i have no idea what a HKS SSQ is?
He he..... no worries :(
yeah i'm finishing early this month, leave at 7:30am!  Will keep that eye out!
I had an overheating problem, turned out i had to replace the thermostat on the weekend, plus i have heaps of stress cracks in the end tanks of the radiator so time to save up for a custom alloy one!
but still got a similar idle issue, i've got down to possible TPS or O2 sensor issues. been playing around with it for weeks now! nearly got my dash finished now too - been making adjustments to make my guages legal - same defect issues as you've been getting!
hahaha...guess i have to start leaving earlier!!! :)
and you did all that yourself? nice!!! hehhee...i love how any misfortune when its car related, always results in a replacement that assists/gives more power :D
yeah...we first thought it was tps...but after changing it, the problems still there....its so strange!!! and as bad as it sounds, its nice to know someone else has the same issue :(
Where were you gauges that you had to move them?
THANKS ANDREW!!!!!! :(
hahaha...guess i have to start leaving earlier!!! :P
Guages were on the a-pillar, now are all part of the dash itself, i had to cut a fair bit but hey it's all good fun. Looks good, now just gotta get the dash sprayed to match the outside of the car.
yeah i always make the most of any issue with the car, i gotta find a tps to swap mine with to test.. might have to take it to a workshop :)
you moved the pillars to the dash yourself? mad!!!!! i wouldn't trust myself with the car! i'd probably hack too much and then have holes everywhere : LOL!!! matching!!! nice! you're cars an awesome colour :)
I've got a tps you can borrow? i swapped it with a new one for my car...and it didn't change anything...so the old one is still good! you can try it on yours if you like?
you moved the pillars to the dash yourself?  mad!!!!!  i wouldn't trust myself with the car!  i'd probably hack too much and then have holes everywhere :  LOL!!!  matching!!!  nice!  you're cars an awesome colour :D
LOL - i moved the guages off the pillar not the pillar itself :)
I would love it if i could get that TPS off you for a bit, just getting really annoying at lights etc having to constantly rev the car past 2.5K just to keep it going! i'll PM you!
yeah both that blue R34 and yellow evo 7 with plate EVO 7 was his and sold to two honky guys.....dont know them personally but yeah the two are friends...
seen both of them on seperate occasions......niiiice...
spotted MIZ-25T 4door r33 on cutting across broadway....
hey frank i found the high boost setting...its da scramble mode...
you know how to use that ?
I saw two skylines R32 gt-r white no plate, gtst black [grrrrr] having a go at cronulla today.
dam all you ppl that are enjoynig your selves out there on the roads and bugger my dam engeneering sertifacations b4 i get back on the road .... bugger the law! hehe ...
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
