im still waiting to get it regoed
i was driving to get the blue slip (yeah right) so it was purely legal. ill get it regoed next week
The guy at the Caltex just along from where I 1st saw you seems to have a realistic approach to the pink slip process. :D
Spotted: Funkymonkey looking like a lost tourist in the back streets of chatswood in teh Ceffy after steak dinner last night :D
Also GTS-33R this morning on the highway at Chatswood
I WAS a lost tourist lol... was trying to get to a mate's house in chatswood, and got hopelessly lost. THen I ran into Carlo and then you... wierd.
Also saw a Silver R33 with a CF bonnet, awfully similar to the one at the meet on Parra road around lunchtime on Friday.
pwnd some R33 N/A that insisted on showing off his revving skills at the lights outside fox studios at about 2am last night. "OMGWTFIGOTPWNDBYAMAXIMAHULEH"
hahaha its a wonder you didn't spot the other 17 skylines that left at the same time :D
That areas like my backyard what was going on down there.
I should have checked it out but that road down to avon dam is my private track causing me to speed and slide and hahahaha...... whoops
funny, I think the same urge came over a few of the cars :D
bit narrow down there tho....long way to the bottom at some places....
Guest
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
