haha - Ok, thought I saw P plates.
Silver R33 GTS-T I think - didn't pay enough attention.
Chrome rims - SWEET look to it too, very clean mate - In penrith in the Car park behind the kebab shop, and tattoo places, and candy shop.. lol
Silver R34 Sedan with HID's, and a black front bar - lives up at the bottom of the wigleys that go into springwood from emu plains.
Red R32 parked outside a restaurant in the main drag in Penrith. GTST I think - not sure - was a quick glance. about 6pm.
I saw the black P plate GTS again about 5 minutes ago - lol.
Thinks his GTS is the sh!t by the sounds of him trying to send it sideways around the roundabout. lol.
He definitely saw me - which would explain his antics. haha
Guest
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
    • Most of the R33 GTST S1 are all like "airbag? What airbag?!"
