funny, I think the same urge came over a few of the cars ;)
bit narrow down there tho....long way to the bottom at some places....
what went on down there????
that long road out to napean dam i nearly hit rock wallaby at about 180 very dangerous
oh yeah on monday I spotted a Gunmetal R33 with a CF bonnet and a white R33 (both GTSts) crusing down Celveland St past UNSW (where I was headed) both with asian guys in em.
Then I parked my car in front of SXY33T (a burgandy R33) in the backstreets of UNSW (down the road from where the maccers is).
Haven't been on here since I left syd, so I thought I'd share :)
Trip to syd was awesome, I'll be back around the 26th of Nov for a couple of weeks :D
I've spotted you there.
Also spotted on Castlreagh street yesterday arvo black R34 GTR plates AWB.
I think I've seen it before at drift afterday thingie maybe... They stand out more in traffic cos it's not surrounded by other skylines.
there sure is :)
if you need tools and stuff ill give you a good price on what i can :D
ooo!! sweeett!!!! i need a screw driver set.... and those thingies i can use on my car.... you know the oneeesss!!!! :(
where is it on castlereagh?!!? i'll come stalk ya! ;)
LoL.. u are good at stalking ppl arnt ya moanie :)
u stalk everyone on here :D
and everyone should be able to spot me soon even though im not in a skyline
just look for the blue lancer with a green door once I get it changed over :(
and spotted a silver line think it was a R33 driving down castle hill road towards castle hill last night around 7 .. flew past didnt get a chance to see person plates and to definatly know the model lol ;)
Guest
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
