Seen 2x R34 4 Doors following me on the freeway F3 (M1) yesterday , the first one turned off at Berowra exit ( old pac run maybe ) :yes: the second followed me all the way to Kariong exit but not sure where he went lost him at mooney mooney bridge, didnt get close enough to see the plates ( had a blonde chick in the passenger seat )
  On 26/02/2014 at 6:14 AM, kaneryan said:
Spotted jasmine (34GTV) at warriewoos again going past the autobahn :)
  On 26/02/2014 at 6:16 AM, kaneryan said:
P.s sounds muh better now with an exhaust... None of this stock rubbish ;)
Haha aw I didn't see you, were you in your 34?
And yessss it's turbo now as well :P
  • Like 1
*jasmine*
I thought it sounded a bit odd when you passed me, I was going to wave but I was in my territory and well, would of just been akward for both of us.... probably more me not getting a wave back hahaha rims look good too :yes: and if I was that observant, I would say you even changed your number plates from pink to red, to match the 37SL's???
Edited by kaneryan
  On 09/03/2014 at 8:48 AM, kaneryan said:
*jasmine*
haha yeah i would not have recognised you, so that would have been awkward :P
and noooo didn't change my plates although I'm so over the pink and my plates in general as its not really a GTV anymore :closedeyes:
  On 11/03/2014 at 10:09 AM, johnnilicte said:
I'm colour blind lol
Haha could've been mine, Ricky's mate also, asian and I wear glasses haha, got.volk gtu which look like bbs lm meshes. On another note spotted Ricky on Hamilton heading home :)
Does ring a bell :)
I was in a purple homo coloured r33 with gtr wheels and gate of course lol
Guest
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
