Dude the 32 in st Clair is nice I hate the kit tho !
He drives it like a grandmas car but at the track he is pumping 300+kW at the wheel
really? it looks like ass haha the wheels and kit are a sin, impressive if it does really have that power but
Saw a black R34 GTT with black wheels at St Marys station just then I think the plates were BNQ-03Q. I was in my mums silver Camry right next to you
That was me! waiting to pick up the mrs. lol first time spotted :D
Woo! I've seen you before sometime last year on the Gt Western but that was before I got my Skyline. I remembered the black on black
Just saw Ricky(LL00LL) passing me while I was parked at Tangerine St, Fairfield East.
Flashed my high beam, saw your hazard light. You've got the High JUN stands now like me. Real niiice in all black!
Had a nice chat with Terry whilst admiring the GTR at the Charity Car show in Springwood. Was nce to meet you. Your car is stupidly nice.
You're very kind Liam. Hope you had a great day! I rolled up at about 11 thinking that all the tarmac spots would surely be taken. Our family only wished to stay for a couple of hours because Maria was on an extended test drive of a new car on the same day. Plus we bought it. So the Cameron Burke Show was only an afterthought. Great meeting with you!
  • Like 2
When will it be mine turn to own such a beautiful creation.
A little off-topic, but do you have any other pictures of this on these forums, or just in general?
I've only been privileged to see 2 or 3 photos of your car, and unfortunately they've all been of the same angle/point of view.
Thank you for your appreciation :)
I still go out to the garage at times to think how lucky I've been.
This N1 has been shown before in...
SAU > Photography > R34s
And if you require hi-res, email me on...
[email protected]
Regards
Spotted the same HR31 Coupe [YRB20T] but driving. Had a quick chat to the bloke at a set of lights.
I'm guessing he works right opposite where I see his car parked all the time, either at the smash repairers or tyre place on the other side of that T-junction.
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
