Official NSW Skyline spotted thread
CerealKiller
**** me dead those rims are so sexy!!! i want in bronze!!!! so noone get them or there will be murder done!!!! :uh-huh:
YAY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! you picked up your plates! :) sweeett! :) when are they going on the car?!
and isn't that thomas' or james' wing!??!?! :P
awww shucks!!! why post i picture of me for! :) you know how i hate it!!!!
saw a 32 parked outside BP on anzac pde at around 6:50PM today (Didnt get plates)
then at Maroubra on Anzac and Maroubra rd, saw a black s2 33 we were at the lights, cbf racing you. I was low on petrol lol :D (Plates were like ATH xxx)
ok i'll make it "official"
UMM DOODZ I SPUTTED AYE UMM WHITE FIRTY FREE S2 ON UMM (shit i cant remember the name of that big road.. james ruse dr?) TODAY AT UMM 2 FIRTY.
I FINKS IT WUZ WILCH! I WAVED N STUFF HE WAVED BAK. HAD A LAFF N DATS DAT
There ya go.
hello!!!that is bcos someone is too busy to go cruising with me!!!!!
hahaha... bintie.. i'm making a date with you... lunch on monday, and cruising dates to follow!! we'll discuss at lunch.... hmmmkkaayyy!!! ;)
didn't you know ruk!!! bwa and wilby are a couple! ;)
LOL
nah i didnt ;)
here's what i've seen in the last several days. white 33 gjr007 rhodes coporate park. black 34 castle hill rd 5.45pm
sat.
yellow 32 george st 9.50pm white 33 george st 1.30am grey 33 s2 ab67ju green p's 2.30am
george st white 33 george st 3.00am white 33 george st 3.05(same car?!?!?!?!) burgundy 33 3.10am george st silver 32 3.15am george st yellow 32 3.35am george st & light blue 33 zamazu parramtta rd 3.45am
Thats the one i've seen parked in front of powerplay imports , not sure if its a genuine "nur-spec ".
There is another bayside blue withe rego plates "NUR" and V-specII nur badge at the rear , iknow thats not a genuine "nur", i have seen under the bonnet of that one .
Guest
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
