damn, thats a lot of lines being spotted..............i feel a bit left out here guys lol.....$10 to anyone who spots me......im desperate for attention.................................anyone...............hello?..........lol........
Yep, that was me.
Saw you in the white 32 gts-t :P
Also spotted MAR-55S, who i believe is also on these forums, turning onto the M4
Just saw a r33 gtr ? gts t near ryde on monavale raod with art 97???? number plates and a www.sau sticker on the back, Played in the traffic and gave it a wave. Nice plates, mine are art 40b...... :huh:
Yep, that was me.
Saw you in the white 32 gts-t :(
Sweet finally spotted and got spoted!!!!
nice work tommy!!!!!
Spotted a r32 GTR with a silver front mount in Neutral Bay.
A r33 with rusty calipers and distinctive plate in North Sydney .. looked kinda dumped cos I wouldn't park a skyline there and leave it sitting for the amount of time it would take for the calipers to get like that.
r33 4 door around the Forest area.
Spotted and drive with a black R-32 (rego "321 GO) on the Bradfield Highway and Epping Road approaching the start of the M2, at about 2.30am Sunday morning on my way home from the city.
Spotted a white R33 on Briens Rd Northmead this arvo around 2:30 -2:45. Had a SAU sticker on the rear window.
I beeped as I went past but was in a Mitso Mirage <---- did I say that out loud
I think that might have been me!
...maybe. I know I was around that area at that time, and I heard a beep. I was looking around thinking, "wtf!".. lol
keep it wilb.. it adds character!
spotted YLM xxx this morning on the highway! (just so I'm not whoring!)
oh also ATN xxx gunmetal 32 gtr.. on elizabeth st on sat night. I'll be visiting you for more parts soon!
do what i did and put your stickers on crooked and get your skyline to do something crazy, like mine (squatting madly) :)
cept i still haven't been spotted. So im gonna spend about $200 on SAU stickers and cover most of my car in them..... That'll be pretty f$%king hard to miss
Guest
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
