That thing doesnt idle properly.
Hes running cams that have a duration in the 280's
It runs like a piece of crap, doesnt idle properly, its a pain int he arse to drive with that clutch, and im sure its pretty laggy.
But it puts out a helluva lot of power. Saw it at CRD when i had my thing tuned, and it put mine to shame :(
Bet ya the price of petrol is affecting him more than me :):D
Apparently the R34 GTR [TURBOS] was imported already modded from Japan and the owner returned it to stock, complied it, then refitted everything. Either way, has huge power and sounds tough as nails. I guess with such big power, lag is expected, but it is an animal.
Tommy, tell me more about its set up - what ecu/turbos/clutch/box?
Charlie -
I dont really know much about it.
Had a look under the hood and saw two massive high mounts that looked like greddy turbos (could be wrong).
Other than what i've previously, I cant really tell you anymore.
Saw DR4GON Green 33 GTS-T at Parramatta on church street near the cafe's yesterday. Looked mad with the chrome spinners and kermit green paintjob. :SAD
Charlie -
dr4gon. lol, I remember that car used to see it heaps when I lived in west ryde.. :puke:
:P
Charlie -
From your post and the fact that you were there when it was being tuned, I would have thought that you would have gotten all the specs :) I know I would have :D
I think DR4GON lives on the Church St strip - I also saw it at City Extra in the early hours of Monday morning.
spotted ECL tonight coming out of the market city carpark and the other night parked in front of market city.
gf lives just off that street so im guess well be spotting each other a lot from now on :D
and in other news......the ONE time I didnt bother to get a parking ticket in front of her apartment I got fined $75 for parking without a ticket..... :)
Edited by shonen
spotted (i think!) ANewTattoo on epping rd about 30mins ago! it was a r32 with a green light over the back number plate... ADnumbernumberletterletter.... i tried to smile and wave, but i only got one brief glance from the driver.. then they turned off somewhere....
From your post and the fact that you were there when it was being tuned, I would have thought that you would have gotten all the specs :O I know I would have :D
hehe, thats tough
i copped a $225 fine today as i accidentally went into a bus lane and got caught by an undercover
its a mixup now that the cross city tunnel opened :)
Past few days I have spotted a white R33 GTR with R34 Wheels heading north on Stacey St, Bankstown at 6:15 am
If its lowered , v-spec and a cannon mufler its probably butthead .
spotted a white 33 s2 p plate at hume hwy turning into bankstown today 6pm, also a silver 34 near bankstown shopping centre around the same time, i was in my stock 33 black with stickers down the door
Guest
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
