On the 26th, spotted a few black R33's on the way down to Nowra around albion park... One gave me a wave :P
On the 27th you would have seen a Green R33 as well. Pity... :P
Saw a Maroon R33 SII heading North through Nowra today 28/12. Veeeerrrry shiny. New paint job ?
Anyone ?
El Bee
saw MAR55S and the previous owner of my car (now has gtr) in the fox studios car park, last night at around 8pm.
also saw a brand new f430 convertible start up and hoon out of there that was nice :huh:
Was that your S2 there.. about 20 meters from where mine was???
I almost parked next to it to take a pic... then i thought.... nah... too wanky
:wavey:
That's bizarre. Fancy the same plate coming out of the registry (close to where your car was initially registered) AND given to some other skyline, which happens to be white, which is owned by a p plater.
*boggle*
Spotted SNG ... this car f**king owns - 32 GTR.
Wow, 3 years of owning a skyline and finally been spotted, i must blend in well. :huh: When was this and what were u driving?
Wow, 3 years of owning a skyline and finally been spotted, i must blend in well.  :(  When was this and what were u driving?
That's twice I've spotted you man! A few pages back I spotted you at the mechanics!. Your car was on the hoist when I dropped my car off.
28th of Dec I spotted you going past crown of the hill (theos liquor) right after the Roseville Bridge. Was driving my white family car. If you're around north shore/northern beaches area and goin for a cruise lemme know .. Love to see that car on the road again :huh:
On the 27th you would have seen a Green R33 as well. Pity...  :(
Anyone ?
El Bee
Sorry mate, was kneeboarding that day :huh: Back home now, and didnt see any other lines coming home yesterday afternoon...
haha dude I saw your car pretty much the first week I got my car....
At the sau dyno day at croydon.......
your friend or brother has a silver 33 with CNG plates right?
hahaha just out of curiosity what does CNG and SNG mean ?
Yeah i was at the dyno day, that was years ago though, can barely remember it. :)
28th of Dec I spotted you going past crown of the hill (theos liquor) right after the Roseville Bridge. Was driving my white family car. If you're around north shore/northern beaches area and goin for a cruise lemme know .. Love to see that car on the road again :)
Yep, im out all over the place which is suprising i havent been spotted before, i'll keep an eye out for you next time. You live near the Roseville Bridge area do you? I guess i'll probably be spotted more often now you've seen the car. :D
tried,but a 4wd was trying to take my lane around the corner.
did you see the maroon 32?
i seen him go up doonside rd the down holbeche.
also OFD14L a maroon 33 lives near me(are you on here dude?)
also has a silver 33 4door i noticed today.
I didn't see any skylines today :)
I usually see heaps around that area though
Guest
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
