spotted GTST yesterday arvo on victoria road.. i think that was you, I was driving my other car, pulled up next to you, was about to yell out the window but then the lights went green.
I tell you, you car looks amazing.
Spotted TRD-33Y on cleveland street around 7ish on saturday, damn that traffic was bad.
Spotted TURBOS at double bay around 1.30am sunday with a ridiculously loud exhuast.
and two girls in a grey R32 GTST on cleveland street 2.30am ish dancing and singing in the car.
BTW, I was in a white R32 GTR ATI-33A
HI!!!!!
Kinda hard to wave :) Thought I saw you looking at mycar :)
I saw R32.. then it was mm GEEEETEEEERRRR :)
Yea traffic was bad, though I made it through pretty goodly :P Did you!
Spotted a dark blue R34 at Seven Hills Caltex/Red Rooster/Hungry Jacks (crnr Abbott and Costello Rds, just past the end of the M2) at around 8pm, but they left before I could go out and have a chat to them. I did notice them looking at my Stagea, though...
Anyone?
spotted 11ty r34 GTTs today in the uni car park... man there are a lot more lines at macquarie uni this year :laugh:
Probably related to the fact that I've noticed that 80% of R34 GTT drivers are Asian.
Spotted AWU-*** dark blue R32 GTST on Pennant Hills Road going toward Carlingford this morning. Hot colour.
spotted SMASHA! on the way to work today near powerplay imports.. cruised together for a bit and also had a chat too ... :)
yes.. I was admiring mansoor's new ride.. looks berry berry nice.
don't sound too bad either
Spotted a black R32 (GTSt, I think), this afternoon on Portico Parade/Toongabbie Rd, heading towards Girraween.
Plate was RLX RE, or something like that... V.V. nice!
Guest
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
