Are you talking about coming from Brighton (general holmes drive) or from the M5..cos if its from the M5 there isnt a camera heading city bound..it sounds weird cos there should be, but i've gone through there at about 90kmh many a time and never received a fine hehe.
it's the road right after M5 joins general holmes drive, and we drive under a 'bridge' thing where planes use to take off.
Spotted again a yellow R34 at westmead hospital with massive wing
Yeah there is no camera there city bound dude, im positive.
Also spotted a Silver R34 GTT along king georges road last night.
Yep.. cameras can only get you from behind.. plus i dont think my warnings go off on it heading citybound only westbound
Thats not quite true. Speed cameras in school zones are actually both directions, and they take the photo looking at your face :wave:
Some friends and I were having an argument in the car one night, and it ended up with my mate saying "Alright I'll prove it to you, they dont take photos head on!".... FLASH... He was subsequently fined :laugh:
Thats not quite true. Speed cameras in school zones are actually both directions, and they take the photo looking at your face.
Majority of the speed camera are taken from behind.
Where was that at?
Spotted [WILPWR] R32 on Woodville Rd the other day.
Yes, some cameras take pics in both directions, for eg, Princes Highway at Bulli. Just look for the (rectangular) sensors in the road in either direction.
Correct but some can take both sides of the road, more of them these days .
You don't have to run the risk to prove it either just look for the marks on the road, they are 1.5 metres appart and the device measures the time it takes your car to cover the 1.5 mts. Thats how it works out the speed you are travelling, keep in mind there are lots of them that are faulty as it has been proven in the past .
One that comes to mind is: The top of Spit rd, catching busses and heavy trucks doing 70-80kmh up the steep hill. The busses later proved that they could only manage 30-40 kmh up that Hill.
I've gotten done for speeding, I asked for the photo because I didn't believe it and it had the front shot... Funny enough there was a car next to me in the photo going the other direction...
Makes you wonder...
Makes you wonder...
When the pic is taken it also shows which lane triggered the camera to avoid any confusion.
Hmmm.. was done many years ago in my old car.. Didn't take much notice of anything pointing towards which lane..
I just thought "Yep, well thats my car.. crap..."
spotted WAR 33R on the M5 last night at about 10ish...
that would have to be one of the meanest looking and sounding GTR's ive seen for a while... nice flame action when gearing down too...i just looked forward and pretended it was my car making the noise...
Spotted a purple R32 in St Clair today was some kind of custom purple with gold/honeycomb colour circle spot things all over it! I had to loook twice to make sure I wasnt seeing things but f*ck me it was the ugliest paintjob I have ever seen on a R32 I was embarrased to be driving my 32 behind him incase people thought I was out cruising with it.
scared to be different i take mate...... maybe if you were driving behind me people MIGHT look and notice YOUR car... instead of thinking it was just some plain boring car...
Spotted a maroon R33 parked in Northmead, a white R33 in Castle Hill on Showground Rd, and a black R34 with two thick white stripes down the centre on Station Rd in Seven Hills.
Guest
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
