Guest barbie iz a bitch
SPOTTED ON FRIDAY NITE... 'JTCOOL' r33 white on Parramatta Rd- 'WATEVR' silver r32 also on Parramatta Rd- white GTST, standard plates, fully smashed rear end! in Newtown.
LOL the JTCOOL was silver r33 and WATEVR was the white r32..
Spotted : Bright Yellow line, just coming out of Syd this morning, to busy staring at it to read the plate ;-) (Lovley exhaust note - Must have been a GTR, but was drooling)
(I drove down from Bathurst this morning, so came across plenty of lines, and any that I didn't wave to, I was inspecting ;-) )
(If anyone saw me on the way, I was in a '96 Silver GTST, Reg: ZebHax - http://212.42.1.197/Zeb/line/line.jpg)
Just saw 'CRAVED' driving past dural golf range...
Im finally back on the road too  :D yippee :D
hey, must have missed you... in my own little world on the way to work..
plus i was practicing my left foot braking --- needs work :rofl:
Saw a white 4 door 34 parked on oxford st yesterday arvo...around 2ish! thought it might have been ABO BOB....but i didn't see the plates :D
Yup that was me. Yay, I got spotted again! What colour are you Moanie? S1 or S2? I think my gf spotted you. She is getting pretty good at spotting now. She's got 32, 33, 34 down as well as 33 S1 and 33 S2 but I don't think even I can do 1.5 at a glance.
hehehehe...i thought so!! you're the only 4 door 34 i know of in that area! :D i wanted to do a u-ey and do another driveby for a better look but we were running late, and i'd have gotten yelled at! :
Mines a silver s2 :) hehehehe...you chickie needs to herself a line!! :) :) :D
1.5?
Mines a silver s2 :( hehehehe...you chickie needs to herself a line!! :) :) :)
1.5?
Yeah series 1.5 has bits of both. I'm no expert on it though. Skylineboy could probably help us out.
yeh I've seen TTL before
Gorgeous car! nice turbo too :(
Yeah that's the one. It belongs to a friend at work.
He showed me the car the other night and the thing sounds like a rotary with all the work he has had done to it. He's gonna take me for a spin once he gets some new rubber on the back cause he can't get the 500HP to the ground :D.
Guest
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
