Official NSW Skyline spotted thread
CerealKiller
yeah that happens a lot...
saw some guy in the backstreets of pymble cleaning what looked like a very schmick and new yellow R34... i drive that way every day and today was the first time i saw it...
doing it with a bucket too, thats dedication :P
Was spotted by a Silver R33 on beecroft rd just outside cheltenham high.. he flashed/waved i returned the wave but did not catch the plates and car didn't look familiar hopefully u will come on here and post up.
saw a white R33 OTH-011 i think at thornleigh maccas last night... had a skylines australia sticker on the rear window but have no idea who it was...
also saw a black R34 that looked very nice... completely standard, but still nice :)
HELLO TO YOU IF YOUR OUT THERE!
Hey mate...
That was me.
Love a good wave and flash
Spotted MARSSS today, turning off parramatta rd Burwood in the afternoon
hell yeah! spotted.. was yrs a 4 door??? cos i saw one when i was waiting at the lights
also spotted teh Sash on Oxford st
spotted "V8HNTR" silver 33, in the city, cruising with a 180... i was the white 33 with the powerplay stickers... Man it feels good to be able to drive again :) miss the little beast..
also had some fun with a 200 an evo and an M3, never new how quick those m3's are... gave me something to beat lol... :closedeyes:
Guest
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
