Official NSW Skyline spotted thread
CerealKiller
No-one spots me either, i see heaps of Skylines on the way to work and back and post it but they must not be part of SAU forum or they just too lazy!!!! =( havent been spotted once in the 2months ive owned the car!!
I've never been spotted even with my custom plates and parking my car in the same obvious place in a busy location 5 days a week....
spotted SAM916 in Artamon, near the tittie bar which I was heading to :domokun:
haha saw you to mate, also saw a massivly stretched hummer just after i turned the corner. I know the place your were going to! (A guy at work organised a free tour there because we 'worked in the area and wanted to become familiar with the local businesses' :nyaanyaa:
Spotted a candy hot pink R33 in Bankstown the other day with a guy driving it (guess he likes pink)
Anyone on here?
there was a guy that came to the coast a few weeks ago, could've been him (did he have 20inch chromies?), tinks gave him a card but haven't seen him on the forums...
Anyone on here?
What was the number plate?
haha saw you to mate, also saw a massivly stretched hummer just after i turned the corner. I know the place your were going to! (A guy at work organised a free tour there because we 'worked in the area and wanted to become familiar with the local businesses' :D
Man that Hummer nuts!!!
theres a few over in Hawaii but first Ive seen here - and the driver I think was a former body guard for a celeb....farkin massssssssive!
Suprised you reconsied me! :rolleyes:
I don't remember, I only remember him cutting us off and the girl who was driving the car I was in yelling "FAG" out the window really loudly :D
Then it took off, dunno about the chromies, but looked to be in poor condition, paintwork-wise
The only pink 33 I know of is in brighton.. and hes one of the guys on here's cousin..
I haven't been spotted either... I saw 4 'lines yesterday between Hurstville, St Marys, Parra and Blacktown waved to some and felt like an idiot when I got nothing back :( lol
Spotted a couple of r33's at livo KK's tonight... one was a charcoal series 1 with whitewalls and chromies, the other was a silver series 2, NVD-33R.
Also spotted a bright orange r33 approaching the elizabeth drive and hume highway intersection at about 11:40pm. Looked pretty nice...
Hi, always see a Yellow R34 in Glebe around broadway aswell? Do you know a Jerry with a silver R34 kinda looks like the one from Fast Furious but its a GTT, well he knows you and he knows me ( Grey Gts-T R32).
Guest
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
