just saw a red stagea, plates were st-45-** or probably not... damn my shit memory!
was nice though, and i didnt flash you cause i was too busy trying to read ur plates, and didnt think you would appreciate high beams in ya face :cheers:
probably coulda honked though...
NO WAY, DUDE! I spotted quite a few people and cars at the AGM too!
Seriously, though, on the way home from there I spotted a white R33 (s2, maybe) with a blonde chick driving it along Old Windsor Rd. I turned left onto Fitzwilliam Rd in Toongabbie to head home, as I figured it wouldn't be too smart (or appreciated) if I stalked her and followed further than that.
spotted a black r33...not sure what model absolutely flying along norwest boulevard this morning around 7:50. And then 2 cars back was the Advan performance echo...not that its relevant but ya know
Got a flash from a guy in a white S2 R33 this morning around 8am in Newtown near the King St/Enmore Rd intersection, I waved :thumbsup:
Any one on here?... I think this is the second time I have seen you!
spotted a silver R32 GTR on the kingsway miranda this afternoon around 1:30ish, i was outside westifleds at the main entrance and could hear this thing from a mile away, so i stood there looking and it went past LOL, sound absoulty MEANNN, dunno wot was under the hood, also had stock r32 gtr rims :thumbsup:
RUGAME. Has over 200 at the treads. Very nice car :)
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
