Official NSW Skyline spotted thread
CerealKiller
Spotted a couple today, there was a maroon R33 with number plates FR-33-SM i think, on the M4 before church st exit
and when i go to watch my bf play bball at the auburn basketball centre there's always a nice orange 33, i can't remember the plates though, big jap sticker on the back window. i love it. :mrt:
hehehe fr33sm thats nick i think... if that is indeed his name... he was at auto salon :) nice guy :O
yep, that's Nicolas, aka NicsR33
I spotted sl33ek at work.
Are there any SAU cars not at Grey Imports atm?
Mine's not there, but I still don't even know where Grey Imports is, so time will tell...
:yes:
hey duncan, havnt seen your stag in a while. you're in w3.a somewhere ay, I'm the asian dude right outside the print room. still dont know who you are lol
Spotted Silver R33 with quarter window SAU stick along pennant hills rd - SQ11SH i believe where the plates said hi hard to hear as the beats were rumbling.
that would be Smasha :yes:
Always see that car in broadway . . . ALWAYS
i was actually parked behind it earlier out front of nandos
Edited by v_s_p_e_c
spotted many skylines in my travels today...
a grey 32 gtr pacific hwy behind me wo turned into kissing point road -turramurra
jst after..
a silver 33 gtst who turned down ryde road
just after again...
a white 33 gtst north bound - flashed lights and got a wave
little bit later...
a yellow 33 with 2 massive cannons....
oh, and spotted a honda -with a typical metro fag in it, popped collar and big sunnies...with the plates
UZD45X
hahahahahaaahha
I lolled alot
lol :P
I saw you parked behind me and was gonna post here as it looks like mass-iv's old ride...
oh, and hi lanky... ;)
Spotted a silver R33 series 2 going eastbound on the M2 this afternoon. Fairly stock looking car although it had a GTR style wing on it. Waved and beeped and whoever you are waved and beeped back :P
Guest
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
