just spotted a silver R33 gtst parked on the grand parade Brighton, trust front bar, starcorp dished rims and GTS badge on the back with the TURBO badge from an xr6 under it...looks the goods :P
spotted 4RACEN at sans souci
I saw that one aswel, looks good
Plus a shiteload more skylines;
Bap 61r or something
r32 4door guy gave me a strange look in caringbah (maybe cause i was parked "not so correctly")
BBY white r33 in rockdale
i gave up counting after 4 cause it got boring seeing other peoples working skylines
While in Bankstown today i spotted;
9 WRX's
5 200sx's
4 HSV's
2 landcruisers with huge bling wheels
7 skylines
1 GTiR
but only one cop :D
you need to find some music or something to do in the car as opposed to counting every car u pass :)
9 WRX's
5 200sx's
4 HSV's
7 skylines
1 GTiR
but only one cop :laugh:
Hahaha thats Bankstown for ya. Tons of lolo's and hot cars. Piggers sick of chasing 'em around. My mum got her Astra smashed by a Skyline in Bankstown a few months ago. The Skyline was a write off haha. :)
Spotted a gun metal grey gtr in the garage next to me at wakefield on sunday!!!! Sorry mate forgot your plates and name!!! Did you get the suss-spension issues sorted?????
Also spotted a silver r33 gtst turning right onto forest way with plates omething like ar - 13 -at that was about 2mm of the ground!!!! Loads of suspension travel on that one!!!!! But ive been told bump stops are the way to go now for new susspension!!!!! :thumbsup:
No that was two black r34 GTTs one was mine and one was james at precisely 12:31 as we headed to the skyline cruise.
Good btw :thumbsup:
both looked HOT !!
spotted RRR-33T burgandy gtst @ blakehurst this arvo
Guest
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
