Spotted a Gun metal gray/ black?? 32 GTR 9am on burrows street alexandria had a sau sticker on the quater window.
Spotted AMY033 on gardeners road mascot.
spotted a white R34 GTR plates CUDERE (see u there? ) on princess h'way rockdale around 4:30 this afternoon
I spotted him last night at around 6ish on wattle street five dock!
i went to parramatta last nite from Norwest...spotted about 10 R33's...2 R34 gtt's....NO r32's!! not happy...also spotted various silvias...just out of curiosity..has anyone EVER spotted me?
Edited by NG0387
spotted a black 34 on the way to the city this morning
then a silver 33 on m2 on the way home this evening
Slim are your plates SL 32 IM or something? Because Im pretty sure I spotted either your car or someone similar .. Saw you racing up behind me in a 32 .. well I guess it was you .. Gave it a wave but dunno if they saw me..
:D
that would be me :D
didnt see the wave though
Saw a very nice black 33 in Ryde last nought around 81sh pulling onto ryde road... Had large decal writing on it, DCD or something like that... was an odd design and hard to read... looked clean though :D
spotted a 32 gtst on somerville road Hornsby Heights this arvo....
and spotted two home and away actors at the narrabeen sands - and got extremely drunk with them hahahaha
i know this is lame....but can u disclose which home and away actors u got sloshed with? just to name and shame basically
Spotted a R33 4 door on the f3 this morning around 7:15am heading towards sydney right at the end bit of the freeway just b4 it turns into 80kms speed zone - then 15secs later a highway patrol lights/siren a blazzing swerving in and out of traffic - hope he wasn't after you.
Then tonight on the way home on the f3 spotted a maroon R33 stock bodykit but had a exhaust can't recall number plates but see it almost every saturday night on the way home from work.
Guest
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
