LMAO what a joke
funny how people who i know saw you thrashing the arse out of it
but it conveniently dropped oil pressure while "casually" driving home
I remember you telling people you were a motor mechanic by trade on jdmstyletuning.com.
If that was true or if you were any good at it you would also know that these engine are well and truly built to be able to handle being given a bit (if he actually was, which I honestly doubt would have been much anyway) unless there was already an existing problem?
Could of been me .. I do drive a r34 .. Starcorps and its very damn clean .. cant have a car that isnt :laugh:
I was playin funny buggers with a 33 on that rd too :D
Edited by DECIM8
Well said Abo Bob, people just drift away.....to different subject ccc. :laughing-smiley-014:
Anyway I've spotted nice black R32 GTR ;) on the Qantas drive. Can't think of the plates but had a weird looking rear wing higher than standard bit like Supra wing - Anyone on Here??
Dave
yep, pretty much perfectly perpendicular to pymble pub ;)
Too many P's in that sentence, Doof - now I have to go to the toilet! *shakes fist*
spotted a few lines on Mowbray rd this arvo a nice white Stagea with white volk challengers on it parked, black r33 series1 parked, & a white r34 4door & an r34 silver 2door driving along...
Was that white Stagea out the front of a convenience store, by any chance? I've seen it there quite a few times, it's a series 2 and very nice!
Maybe, but i think it was out the front of a house. It had a Tein sticker on the back left of the hatch lid, & yeh def series 2, looked nice ..
WPN - I spotted that stagea also!
looked nice, needed a clean though ;)
Oh, and spotted Saaaaaaaaaaaaaaaaaameh at his house! :)
I had fun driving that truck! Love the exhaust brake noise!! :)
man, sif not grab the phone while you were there :P
Spotted a white 33 s2 "LI 11 NE" in norwest fitness first car park, and also a white nismo kitted 34 GTT in the same car park, plate were "ZNE.. .." i think
and also a white 32 GTR on old windsor rd
Just saw a skyline in Pymble Corporate Centre... twas Gun metal Gray and for sale...
Also, the silver 33 (AQD 38T) works around here, and so does XCLNCE or however he spells it
:) also
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
