Just wondering if any Coasties happend to have been in gosford last night around 6 - 6.30 and see someone smash into a
white R33 GTST -plates RB-25-MD and drive off??
Well thats the story i was given anyways... lent my bf my car and he picked up up with the front bar all smashed...
said he had it reveresed parked into one of those new park spots @ kibble park near woolies, and when he was inside the shop someone
had lost it and hit it..
OR...did anyone happen to see this car run into someothing??
Would like to beleive his story... but considering how bent the reo bar is..the impact must have been pretty hard (im thinkin he lost it in the wet round a corner or something but doesnt wanna admit!)
Anyways... just thought i would see if any of you spotters had spotted anything!
thanks guys!
Mich
spotted a black skyline at erina yesterday arvo around 4, think it was br3tt off these forums, your girlfriend was driving, i was pulling out of the driveway for supercheap and you went into the next driveway, cant remember the shop tho. i had to stop at the lights and saw you get out of your car and stare at mine for a while lol
i was going to wave but i didn't want you to look at me funny just incase you weren't off the forums lol, nice car btw
Nah wasn't me... my car was running like a bag of shit tuesday and sat in the garage and my girl can't drive manual :/
well anyway, was it anyone on these forums
Edited by weeman1
Maroon 32 GTR on Pennant hills Rd plates MEL ##H cut off some guy in a ricey lancer turning onto Windsor Rd or something. tad grotty, but very nice none the less.
I've spotted that guy before. I think that's an Aussie delivered GTR.
spotted caine... skz01d lol
aka -MONA-'s boytoy, at work today... small world, he works in the same building complex as i do and i never noticed till today :P
Edited by mass_iv
So both of you work on Oxford St right?
Spotted a clean white R33 GTR in carlton lastnite and a black R33 gts thru Hurstville with some bright ass xenons on.... also chased, caught, passed and pulled away from a yukky looking purpley bubble gummy supra all in last nite events....
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
