Whatever happened to crawling before you walk
:) he is a rexy boy tho :rofl: converted now hahaha
there's yr answer right there...
Spotted a silver 33 with wheels and what sounded like an engine in it... then i drove it.
good to hear the z tune has been sold. previous owner wanted to modify it which is a sin in my eyes - there are plenty of crappy r34s he could have started with instead of that.
20 car limited edition should be left in mint factory condition not molested.
there are plenty of quicker gtrs in aus that the z tune so just LEAVE IT ALONE!
yeh i know.. the thing is he did modify it, but luckily kept the original parts to put back.. the sound system is the only extra now, its ok tho i had a look at it yesterday its pretty neat and can be removed easily.
also the Z-TUNE will not be in AUS for long :D the new owner will be taking it back home with him, i cant remember where tho i forgot lol i was too busy perving at every inch of the car haha.
unfortunately its his money and yeh i guess he can do as he wishes lol...
it wont go for about another 12months tho.. he is here on a working visa meh so gay... he is only 27 :teehee:
Freakin hell. Youngun with money to buy a z tune in aus then ship it somewhere else. Wish I had money like that.
also the Z-TUNE will not be in AUS for long :yes: the new owner will be taking it back home with him, i cant remember where tho i forgot lol i was too busy perving at every inch of the car haha.
He is Greek..
Most of it wasn't his money anyways.. His mother bought it for him and the rest was financed..
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
