Saw a black R32 GTR in pymble going southbound, a white R34 going northbound in Lindfield, and finally a black R33 northbound in Chatswood :worship:
Oooooh... the black 33 could of been me!!! I was half asleep and didn't see nothing!!
Did you turn onto Pacific Highway from Boundary Road? You wudnt have seen me, I was driving undercover in a lil red rocket (87 Barina) :worship:
saw MZR33T
well just saw the plate as you passed me while i was waiting at the lights
back of wahroonga somewhere
woot! Spotted twice in one morning!! :worship: Were you in the black 32 waiting to go straight and I was turning onto burns rd?? I remember seeing stove lights on the way round the corner but was too late to look back!
Did you turn onto Pacific Highway from Boundary Road? You wudnt have seen me, I was driving undercover in a lil red rocket (87 Barina) :D
Yeah that twas me... :P That would explain why I didn't notice!! lol
woot! Spotted twice in one morning!! :thumbsup: Were you in the black 32 waiting to go straight and I was turning onto burns rd?? I remember seeing stove lights on the way round the corner but was too late to look back!
yes yes but i have to take your word on the street names
Spotted an r33 s2 silver with a bodykit fitted but waiting to be painted going past Eastern Creek raceway maybe 10.30am or so ? i was in the work ute also spotted an r33 s2 white going past me on burnett st merrylands i flashed you.
Last 2 mornings I spotted a Midnight Purple II R34 GTR rego XX34XX in west ryde on vic rd near the shell yesterday and today at the intersection of Adelaide St and vic rd. Looks Hot as! wouldnt see me i was driving my red corolla yesterday and my dads commodore today.
WPN - that was James, Lingeringsoul.
I also spotted a few guys today
Brad,Anna, smoky, doof, Kell, James from SAU NSW
and vrom SAU VIC - Mav, Scotsman, Bec, and a few others!!
Also spotted 321 GO R32 after leaving EC today ;)
And spotted my car after to weeks
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
