Spotted a p plater in a silver R34 cutting me off without indicating then swerving into an exit lane (also without indicating) going towards Maitland. Not a good way to make friends.
All on my way to work this morning,
silver Stagea in chatswood, northbound
silver R33 'Sqiish' in Ultimo wth sau stickers on the windows
and gunmetal series 1 R33 next to my work wit a disability label thingo;)
spotted jon yesterday arvo and i know u spotted me hahah
Haha yep, definitely spotted ya! Arm out the window :D
Spotted a Silver R32 GTR on Castle Hill Rd on Saturday near the middle of the day... He flashed me but my g/f was driving so I couldnt flash back (I asked her to flash but she said I needed to get a few drinks into her first!) :O
All around 6:45pm, waved at a guy in a gunmetal R32 GTR on Pac Hwy between Mt Kuringai and Berowra, then another gunmetal R32 waiting to turn over the bridge at the lights in Mt Colah and spotted a black 200ZR in the Mt Colah Maccas drive thru (Anna?) :D
it was me @ mt colah lights
i waved u waved
what r u doing tomorrow nite?
come out for a meet @ P6,
sounds huge
Spotted a few lines today.
-Silver R33 GTST with exhaust, HKS power sticker on rear bumper, p plates- spotted on Narellan Road, Campbelltown. I was next to you as we turned right at the lights.
-White R32 GTST, being followed by another silver R33 GTST- spotted near Picton
I spot many a skylines parked in my street of an arvo after work... dunno why...
If you go to North Shore gym, or work in Bridge st Pymble... HAI! :P
AQD38T - grey 33
a grey 32 all the time
white 33 GTR INHEVN or something... might have plates mixed up...
:P
squish is Smasha.
I iz famouzz
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
