Must of been some other nugget cos my plates are AR-36-UA now lol. RTA has to reissue me with osaka cos it ran outa rego for over 3 months, should be ready in a week or 2.
naaaaaaah was definitely your nugget i didnt see close enough to read the plates :rofl:
naaaaaaah was definitely your nugget i didnt see close enough to read the plates :)
U dumb ass i was playin guitar hero3 at a mates house till 12am then parra for coffee. I didn't even go live that whole weekend.
Ur more likely to spot me out ur way. On that note how safe is my car in st clair?
you got clones then!
guitar hero 3 is a pretty homo thing to be doin
st clair is.. ok... depends what street.. it's safer than alot of suburbs thats for sure but still i prefer parking off the street
i've always parked my car on the lawn behind the hedge and haven't had issues
Spotted on sherwood rd merrylands, 3 sexy blue cars all together looked like they were headed for a cruise. R34 GTR Followed by a sexy ass R33 GTR with sexy dish! also followed by a sexy 03 WRX with leather & sexy wheels very nice...
and you know this because..........
because i'm a perfectly straight person therefore have a good idea of what is normal activity for a straight person like me. guitar hero does not fit this description unless you're 10.
spotted a black (or dark colour)r32 gtst in hornsby at bout 6.00pm tonight plates ahtxxx cant remember the numbers.
was just near the station pulling away from the traffic lights and testing the rev limiter at the same time!! sounded sweet!!!
Edited by Mini R33 Skyline
Spotted a White V35 Sedan maybe pearlescent, lowered, dark tint, nice body kit no idea which brand, and couldn't catch the number stopped in traffic outside epping station heading towards pennant hills rd on beecroft rd at like 6'ish i think it was.. i was on the side walk waiting for dinner.
got i waved from black r34GTT with green ps on anzac parade early this morning, while i was walking lol
and spotted a white R34GTT with plate "BAU..." on oxford st and another white R34GTT on geoge st
Had a black R32 GTR done up JDM style follow me down carlingford rd onto beecroft rd where i turned into epping. Didn't catch number plate. Had a big crucifix hanging from the revision mirror.
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
