Spotted the following yesterday after work:
R34 Silver 4dr with Nice Enkei's on Allambie Rd
R34 White 4dr with a few mods on Pittwater Rd heading to Manly through Dee Why.
I waved but couldn't see a response from either due the tint on all cars!
Do you live in the area ? Was it pearl ?
I was headn up the coast, through to pennant hills rd. It didnt look like it had a pearl to it, but maybe it did i was headn in the opposite direction :D
Was it you?
Was it you?
I live in the area and I was on Oaks rd about then, I would say It was me in this .
spotted a silver R33 GTR outside hornsby nissan at about 1.30pm this arvo.. had 34GTR wheels and dropped on its ass..
Hey that was me! Except my R33 GTR is White and yes it is too low. I'm getting some new suspension to raise it back up a bit. It has destroyed the lower lip :D
License Plate: GD2ILA
spotted three skylines in mt kurangi area this arvo
R33 GTST black
R32 GTST black
R34 GTT silver and dumpt!
Hey mate were you in the silver R34 that waved at me coming off the bridge in Mt Kuringai? I was the black R33 that took off from the lights for your enjoyment :rolleyes:
na i saw that R34 i was in a silver 07 model camry (workmates company car) but all three cars looked great!
Ah ok thought it was my mate's R34 :P it belongs to Brenno34 on here and mine is the black R33 you saw with carbon fibre stealth spoiler and gold 5 spoke rims :(
Edited by Zilch*
Spotted Anna yesterday in the knight rider machine on pacific hway
and spotted DJ Wayne (Brave) giving the big finger to who I thought was me... so I gave him one back... turns out he was doing it to some knob behind him :P
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
