If you read the instructions provided with the Spitfire coil packs - it tells you to change the igniter pack and install some 50 ohm in line resistors from the ECU to the GTS-t igniter pack.
It will work for a while, but your igniter pack will shortly fail along with the ECU.
Spotted GTR032 at the tav tonight.. the car and the person.. sorry about the drunkeness and me running through the carpark of the tav chasing after you!!! i was a liitele off my nut and still am!!!!
I think you scared him taiya, i heard you invited him in for a drink naughty.gif
were you in your car, and did you have a squirt? :)
i think i was next to you a couple of weeks ago on george st outside qvb one firday or saturday night actually :)
Unfortunately i was in my shite work van, so couldn't give him a wave or whatever ;)
hmmz yeh could of, haven't been in the city too much lately but yeh
:) I thought RB31DET was a big block, not a 454 :)
Spotted a gtst with a noisey blow off valve trying to keep up with the Z on the way around the bay ;) not for long :rofl:
Also spotted CER34L and an MR2 at the Ranch in Ryde today
hehe yeh saw this pissed as girl last night in the tav carpark chasing me, was trying to ramble on about something...
ehhhmmm??? Thats not very nice! At least I got your attension! And your still talking to me so I musnt of made that bad of an impression :)
Guest
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
