Spotted Dr Doof in Asquith :banana: and then about 20 seconds behind him a white R33 with a stealth wing and a silver R34 4-door with blue plates.
Also spotted a silver R32 gts-t pulling out next to the AMF bowling alley in Hornsby a couple of chicks in the passenger and drivers seats.
All at about 2:15pm
spotted zilch, even though he was ninja :banana:
also spotted a white 32 AR86-- heading along pennant hills rd
and spotted a red stag when heading back... i think
edit- OH that would have been Hempy and Drew... I met up with them earlier :bunny:
spotted a gunmetal grey 32 gtr today on central coast arond gosfordish area..
RIP V8.. sick # plate & tough looking car :thumbsup:
Thanks mate :) - were you in your 32? I didn't spot any lines around gossy...
Spotted a black r32 gtr on the f3 friday morning with green p's.
it's possible it wasn't them... was the 34 a 4 door? did the 33 have an unpainted front bar?
Pretty sure it was us.... just zilch hasn't seen us in so long and hasn't seen the mods to both cars that it was like seeing us for the first time all over lol.
Guest
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
