Was just driving behind a black R32 GTS-t with GTR wing, lowered on stock wheels. HCR-23T plates. I followed you coming off the M5 and heading down the Princes Highway. I saw the SAU sticker on the back, but I was in that black Getz (company car) so it would've been a bit confusing had I waved.
spotted a few skylines over the weekend. spotted a midnight purple (i think) R33 GTR in penrith with plates R33 GTR.
That'd be Mitch (mr moo). Gold plates with black text? They're from South Australia, from memory - he's going to have to give them up eventually. :D
maybe...i thought they were black with silver/white text but i could be wrong...such a clean car wasn't taking too much notice of the plates lol
Mitch has already given up his old SA plates (which were from the previous owner), and now has regular NSW plates on the car - no special number sequence on them or anything...
Spotted a standard white V35 sedan at the end of my street, then another white V35 coupe with mags and a Bayside Blue R34 GTt on Old Northern Road in Castle Hill.
spotted a maroon R33 driving thru epping about 20mins ago... i was a couple of cars behind ya. Didn't catch the number plates but it was running ritch as i could smell ya from way back lol
Spotted a lovely Silver R32 GTR today along Mona Vale Road just before St Ives. Had an SAU sticker on the rear side window. Fairly dirty at the rear end of the car. Number plate was 'AQ 92 ZI'. The guy driving it was very conservative, good driving :O If he's online here I was in a white Peugeot 206 just near the petrol station at St Ives shops.
Peace
Thats was me :)
Was heading upto Newport Arms for lunch/dinner
Spotted a sliver 33 GTST with plates "SQ 11 SH" outside Epping hotel at like 1am yesterday/this morning
Seen it round there before, has SAU stickers on rear side windows
Guest
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 馃槀
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
