spotted a bayside blue R34 GTR last night on Samantha Riley Drive...couldn't see plates tho...i think there was a "T" in them ;)
also at the woolies servo in northmead, there was this black Dodge Nitro, with Spin City and Clarion stickers all over it..big wheels..looked p0rn
Spotted SAM 916 cruising down Epping road
and before that a silver 4 door R33 crossing over to Macquarie Uni
and before that a Silver R32 with a black or carbon fibre bonnet on becroft rd with a SAU sticker on the side window
I saw SAM-916 last night on Pennant Hills Rd up near Beecroft Rd. Little beep and a wave when he turned onto Castle Hill Rd. Nice looking 33. :( I couldn't see a thing through those dark window tints! ;)
Edited by HuH
Spotted a 32 GTR as I was coming out of my street, AWL01D possibly, but not sure
Spotted an S15 with rims, kit, wing and shopping list at the next street, he's been to the thursday cruise, sorry I don't remember your name mate :D
Spotted HOM11E on the next street :down:
Then spotted a white 33 on the next street next to a convertible 300zx
THEN spotted a pretty nice 350Z behind me at the lights at the turn off for the freeway in waitara
Spotted Moei on kingsgrove road along with alot of wild cars even a GT500 I think (im no american ride expert) Also spotted two unlucky kids run into each other at a fairly quick speed. Hope your ok.
hey nath ,
must of been my mate driving hes been using the 34 for weddings ...he was telling me big line up of cars for this one....
Is that blue R33 the non-turbo one I've seen around?
nope its a 93 gts-t, just got body kit, custom blue paint, 18 inch chromes and some chinese made blow off valve..... looks like a toy car now :)
spotted a crazy lambo:
saw that same labo on pennant hills road about an hour ago, seen it around a few times in the last few weeks...
LOL Moei next time you wanna lend out your gtr let me know haha
Yeah couldnt see the driver just the ride, figured it was you as you live close. The turnout was good couldnt believe some of the rims I spotted some bloke had about -30 on massive rims with dish ive never seen!!! like 30CM!
Guest
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
