Sold my R32 out at Oran Park this afternoon to a guy from Canberra. Keep your eyes out for it travelling south. It will be missed. :D
Also saw so many absolute cocknuts leaving Oran Park this afternoon while I waited for my lift home.. For crying out loud people, you ALL look like complete f**king bell-ends when you boot it out of the driveway and hang the side out into the guard rails. Grow a pair and grow the f**k up. ESPECIALLY those of you who are driving Skylines. It's no wonder they're targetted by the 5-0.
spotted a white R33 GTST in bowral. then saw a white R34 GTT following
my mate luke in his gold 180SX an hour ago.
R33 GTST is Reekie, 335kw and simmo's R34.
Saw R33 GTR Fri Nite about 8:30 in bowral Yellow with WAR31R Plates, also seen this car a few times at Autosport.
Also saw twice cant remember wat day but a white R33GTR, didnt catch the plates but it had some fkn nice wheels on it.
My Girlfriend sent me an sms yesterday asking me if i know someone in a gold R34 with the numberplate "NUR" driving through wahroonga....
Also saw a black R34 in chatswood today parked outside near marcello's.
Guest
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
