not a line spot but spotted a 4wd towing a boat on a trailer pop off its right wheel at thompsons corner penno hills road while it was still driving.... the tyre/wheel came flying across the road and i missed it by a few meters, and the wheel arch went up bout 5 meters in the air..... sparks sparks and more sparks....
oh it was thursday night bout 12:20.....
poor buggers
spotted a black 33 gtst in moorebank maccas car park, maroon 33 gtst in moorebank subway carpark and a gunmetal grey 34 gtt turnin onto stockton ave in moorebank from livo direction off newbridge rd.
I saw one parked tonight in the Grand Mercure parking lot around the corner from the casino. It was a black one too, so it might well have been the same car, who knows...
Spotted a black r33 this afternoon goin home from Mascot plates axd**s nd also on the way to the gym near liverpool spotted a Silver r34(near liverpol catholic club) :whistling:
That sounds like natetune's old black 33. End of the plate 34s?
spotted red/burgundy r33 (ND.***) down delhi rd around 9pm driving like a tool (must have just watched fast and furious)
Idiot comes from behind, merges in and nearly hits my car in congested traffic and put on hazards??.... wtf?
mate, if you are gonna put rice lights on your car, at least have the decency to put red bulbs for lights and yellows for indicators. Worst mod ive ever seen.
If anyone knows him, tell him he looks like a freaking try-hard
/ends rant
Guest
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
