spotted a white R35 on Windsor road on saturday,
also spotted various skylines including a black R34 GT-t yesterday on windsor road, and a silver V35 with a Corrective Services officer driving it :D
Spotted my parked Zed being hit and run side swiped by a cab today.
Yep- that car is truly cursed :laugh:
look in wastelands, there are more people that are unhappy with the way taxis drive with photo proof, you should go in there and confirm to them what happend to you....
hope the damage isnt too bad
cheers :P
actually the damage is decent - definitely no way they could have not felt the hit!
Spotted white 34 yesterday Arvo PL?4ZN had a chat at lights St Marys nice bloke.
Spotted silver 33 m4 city bound around 1:30 today FST 666 if i remember, sat behind me for 30 seconds then took off into the distance.
Guest
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
