Spotted cassbo at west gosford maccas around midnight. Guess you guys had been on the thurs night cruise. I was in the 4 door :)
lol out of all the Skylines you spot, you spot my stock box :P
Spotted Pezhead, Bobbeh and Eug yesterday at OP GP, as well as a Silver R33 GT-R, what looked to be Jess' white R32 GT-R, a black R32 GTS-t, a white R33 GTS-t S2, a black R33 GTS-t with R33 Brembos, two R34 GT-Rs in black and millennium jade and two R35 GT-Rs in red and white ;)
I was out at OP too and what a top day. There were so many nice Skylines out as Cass mentioned. The Red R35 sounded down right Mean which would indicate it has had some work done - at least exhaust.
The Jade R34 GTR rego"NUR" (not sure if original N1 but had the badges) but they weren't driving it that hard.
Top job to Cass for whip'n me by .6 sec in a stock R33 -vs- GD2ILA GTR :P
I gotta learn to stop smashing the loud pedal drive smooth and brake late.
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
