Yeah I spotted that this arvo.... Number plate was GTR.32X, very very loud, looks as though its got an extremely free flowing cat in it aswell lol, very wide rear tyres and super super clean....
Made my r33 gtst sound as quiet as an electric car when i was following it
The car is a machine!!!!!!!
Spoted Lanky71/Drew about an hour ago.. was walking to the shops and you drove past
Pitty it was such crap weather... you missed seeing a car accident at the corner there by like 15-20mins.
Took the gtr for a scenic drive around the city and beaches and stuff... we was bored. lol
spotted you again! at least this time you saw me for once haha :3some:
Yep true true, this time heading to darlingharbour for the night out, spotted sam916 in the city on george st at like 2am hempy/qantas was behind me... then a black r33 further down the rd.
Spotted a clean looking white R34 this morning at just before 8am i think, in Hornsby on George Street. (looked like URAS front bar??) :P
that was i sir.. on the way to work. full s1 uras kit. :P
spotted a maroon gts-t on some police tv show tonight on channel 7. the guy got defected and the presenter kept calling it a GTR.
ooh that would've grinded my gears,
you know what's a similar feeling...
I'm a guitarist, and it really sh$ts me when I see actors on the telly pretending to play while they lay over a recording and when the show takes it further, tries to make look "real" by making them move their hands up and down :P
It's NOT a FARKIN GTR and THEY'RE NOT really playing!!! :(:(:P
Guest
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
