Spotted Lizzy in her red 180sx this morning at the big dipper on new line road, i didn't know your a country girl aswell?
yaaa... im from the Dural area. Quite a few of us around that area now!
ps. you didn't even wave back! unbelievable!
lol
Spotted a white 33 being booked by the po po heading north on Southern Cross drive just after the airport
Also a few V35's rolling around the sylvania/chronulla area.
Funnily enough no one as yet has spotted by feck-off-red v35 :thumbsup:
lol
Hahahah i didn see the wave, i only noticed the number plate at the last second lol and there were idiot drivers infront of me who kept brakeing up the hill
lol
im working at galstone at them units behind the village shops
also spotted a r32 in the morning on carlingford road and also today in the arvo a r32 gtr at the mechanics opposite st george tafe
ahhh at the moment ive booked out about half of hills storage at galston, i was there today,,,,,,
Guest
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
