I drove to Bowral for the w/end - saw so many stinking skylines but only 1 recognised my car and flashed/waved and that was a S1 R33 Gtst w/ GTR front bar, plates FLYXXX (X = something i cant remember)
Saw 2NTYSU in bowral, nice white S2 with white rims, another white S2, a wine red S1 on the way home on M5... saw tonnes more, cant remember them all. The car scene in Bowral is pretty impressive.
Christian
Christian
woohoo somebody finally spotted me!
its a trust copy front bar btw :cheers:
I saw somthing... It looked like a series 3 R31 rear end had badges on the back that said 'turbo' and 'Passage'. It was a 4 door but seemed not to have the middle pillars (is that the 'B' pillar?)
It was at Coogee on Saturday morning or whatever time I got there for breakfast.
Saw a nice lime green 32 coming out of Panthers around 2am Monday morning, and 1pm Monday a dark blue 32 (MIDN9T?) going up the M4 at Emu Plains.. heaps of others over the wknd as per usual these days..
Spotted R33 series 1, 2 tone 4 door on Princess hwy out the front of Tynan motors.
Plates: MIZ 25T with green p's
CAR: Has 18's, backs are dished and aftermarket BOV & Exhaust...
Was a very sleek 4 door....
Oh, was also missing a passenger side mirror... :cheers:
I spotted this car on Sat Night in Cronulla...... Remember because of the hanging mirror!!!!
Jono - what power you making now ?? Ummm if my memory is right (too many beers) - Ahhhh I don't even remember ----->
60rwkw is a great gain - NO A TOPS GAIN!
Well done mate :)
Now making 248rwkw's, good gain up from 188. Added Power FC, Cam gears and 2 pounds of boost (12 up to 14) :)
hahaha... well when you subscribe to a thread, you tend to keep checking when you get replies :( also got that thread via e-mail as well! ;)
also spotted a darkish 33 last night... around 11ish... thanks for the games from the m4 down silverwater rd :)
Guest
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
