spotted greyish, maybe gun metal gray r34 vspec 2 gtr, with the plates vspec2, on forest rd penshurst dominos, i was the half naked guy standing on side of the street with a dominos chick in a square suit made of pizza deals :D
oatley on friday saw a white r33 GTR parked outside coles then a black R32 gts
then saturday saw a white R33 gtst cruising next a white ferrarri which im pretty sure is owned by one of the queens st customs guys at their shop, the one down the road from bankstown airport (not sure of suburb)
Just spotted a white r33 gtr on Richmond rd/ Knox rd, looked nice except for those ugly bling bling tail lights..
U gassed it at the lights abit,, were u wanting a race? Abit silly since I had a 7yro in the car
Cruised with a black na R34 4door along Pennant Hills Rd and up the freeway all the way to the Gosford exit at about lunchtime today.
Edited by Jay.R34
Spotted Mr Doof in Chatswood area on Friday night on the way home from Twilight drift. Turning right onto pacfic highway. Was in my mates car so i just yelled at you haha.
Spotted a white V35 sedan parked on Hawksbury Road in Westmead today, behind Westmead Hospital.
Also, I've been spotting a non-turbo black R33 coupe parked in Girraween on Targo Road a few times lately.
That was MEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE..............................
i spotted you on the M2 made my way up to you, was great i had Eye Candy pretty much all the way home, Just moved up there :D
spotted a KV2 silver R34 coupe turning off Prospect Hwy onto Station Rd in Seven Hills
Also spotted a wingless gunmetal grey R32 burble past me turning off Prospect Hwy onto Lucas Rd in Seven Hills
if any of you guys are on here, heya, i was in the black R34
saw this in chinatown other day, opposite the capitol theatre and harrys hot dog stand..beautiful in nismo blue.
spotted the white one on bathhurst st last week i think. sorry, slow at getting phone near the laptop :P
spotted silver series 2 on james ruse drive at around 2ish i think it was
spotted a white 33 on the freeway heading south bound
had GTR kit on it * could of been a GTR *
Guest
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
