spotted RB25DE at sutherland train station! (just went past it)
and RB25DT is in wollongong i think?
Goddamnit I wanted those plates!!! hahaha (rb25de).
I've seen a few cars around, too many to recall... I drive a Silver 33.
Some memorable ones; black R34 on showy
White, modded, R33 on showy
Black 32 GTR ripping up the Airport a month or so ago. (stared him down, then said hi. He gave me the biggest smile, it made my night!)
Of course, I see Luke in his white R34 and white CF bonnet frequently! We've got to catch up again!
Btw; thanks for all the waves to those who do. It makes my night when other skyline drivers wave back :)
Spotted "HKS850" R35GTR cruising along spit bridge, turned right down towards manly. Almost jizzed my pants when i saw the numberplates and hoped what it said was under the bonnet lol.
Spotted a grey/dark silver R34 GT-R tonight around 7pm, travelling along Old Windsor Road in Seven Hills. I was waiting at the lights to go from Abbott Road onto the M2, the GT-R was heading North-West.
Spotted quite a few R34s today, all except one were GT-Rs. Spotted two dark silver ones, a Bayside Blue one, and a silver GTt.
Also spotted two V35s (a silver four-door and a dark blue coupe).
Spotted today, White R35GTR at Taubmans in Paramatta.
White R34 GT with carbon bonnet at Church ST Maccas.
White R34 GT at servo next to steak house on Windsor Rd near Blacktown turnoff.
Spotted white R33 with stock wheels driving towards Richmond past the Windsor 7/11 this morning
A black R35 GTR at Wisemans Ferry parked in the park, 'jack' plates, nice!
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
