2 silver R35s in the space of an hour!
one at the original harry cafe de wheels down in woollomoo and another heading to edgecliff at about 1426 today, plate '206' anyone know what that could mean? the plate not the co incidence.
oh and a burgundy R32 gtst parked just after brookvale oval with plates MIX 32T, very clean.
(last night a light coloured R34 gtst AWK 973 driving very slowly along parra road towards the city through annandale.
R35s still have a lot of presence don't they.
206 Numeral-only plate - my guess is it doesn't mean anything; the numeral-only plates are quite valuable, the fewer the digits the better. Often used as a status symbol and/or investment but values seem to be very speculative.
dropped the gf back to dee why and spotted these on the journey..
the pictured r34 was in the back streets of dee why about 1130 am and gave it a bit of a squirt when he saw me in the rear view mirror, had a hard time keeping up until he parted ways with me at a roundabout, think i saw an SAU sticker so thanks for the run if your on here.
also an r33 that looks identical to mine ARR 42V at 1210 near warringah mall and finally a white very clean R33 GTR parked only military road mosman facing away from the bridge exit, god they look soo much nicer than gt-st's...sniff.
Edited by hamiltonau
Spotted a dark purple R33 GTSt this afternoon rolling through Toongabbie. Spotted it turning onto the railway overpass bridge, then turning right onto Fitzwilliam Road at the roundabout.
Guest
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
