Official NSW Skyline spotted thread
CerealKiller
Spotted Humbla on the Hume Hwy yesterday and cruised together for about 20k's. :action-smiley-069:
Our lil cruise was nice till a fool cut in front of me and slowed down.Was lovely to see your smiling face again. :action-smiley-069:
Saw 2 White R34's separately 30 mins ago at Bella Vista. 5:30 PM
One going going north on Old Windsor Rd passing the traffic light near BP gas station and Maccaz
I was exiting the gas station so couldn't get a good look.
and the other one parked outside 20 Lexington Drive. Had no spoiler. Love the body! thumbsup.gif
This thread needs more ictures of spotted cars. I have been on here searching for any spots of my old car... I miss her. And RTA search reveals number plate has been changed :( Will I ever see my baby again :unsure:
Yer on green parker and one head light lol i thought was 32 rear 34 front but didnt get a good enough look at the rear.. You wouldnt have seen me i was in a green 2011 fiesta :-P
car looks phat mate..!!
Hahah yeah.. the dreaded one-eye r32 headlight ailment..I need to pull the lightswitch apart by the sound of things :rant:
...and the green parkers certainly add some wank-factor :rofl2:
It's a work in progress, though it'll never be a show car I like the 'beef' that the wide 34 panels give :turned:
Guest
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
