Hey guys, I have a R33 GTR bonnet here, alliminium obviously
Has a single vent in it and has been professionally installed and painted,
is the standard midnight purple colour from a 1995 GTR skyline
also has a N1 lip that was broken off, but could be silliconed back on with no trouble!
I have no idea what its worth so lets start at $1000ono for bonnet and lip. I know the lips are worth $700 new from nissan.
no pictures sorry at this stage, will have some on the weekend as the bonnet is locked away in storage!
I can post it but its not going to be cheap lol!
https://www.sau.com.au/forums/topic/291955-r33-gtr-vented-bonnet-with-n1-lip/
Pic please,like to see where and how the vent installed and condition of lip
cheers
Pics are coming guys i have it in storage along with alot of other parts and its about an hours drive, im going up next week and will be taking pics!
I have found out that I can post it... But its not going to be cheap hahah
Track this thread pics up this weekend!
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
