it is simple physics really i would draw you all a picture but should not have to explain myself. if you notice as you raise and lower a car your wheels will move in and out slightly this is the pressure i am refering to on the strut. do any of you back yard mechnics do things the correct way or just bach things out?
As I understand it the strut should neither be in tension nor compression with the car on the ground 'doing nothing'. Ergo, if you remove the bar it would make no difference to the 'sag' (if you like) between the two towers and so your (effective) alignment would be the same.
OTOH if you put your bar on with the car jacked up, the bar would be in some compression when the car is back on the ground, and yep removing the bar would change the (effective) alignment. By how much I dunno. Probably negligible.
you are correct with your first comment if there is no camber and the car is on flat ground... but i also said do not take the tyres off the ground just the weight off them, also the strut will be under slight tension or compression that is the reason for the adjustment bolt on the bar... we dont know how tight or loose his adjustment is unless you have seen the car.
i was trying to give some easy tips rather then just bash it off or get bigger muscles. i would hate to see some of the repairs (botch jobs) done on some of these guys cars.
Edited by NISMOGTT
Lol well to make sure its sharp im testing it out on your brake lines k :P
None of these suggestions have worked by the way... Gonna take it to my mechanic tomorrow, he might give it a go with the rattle gun. Turns out they are on there really tight, its ridiculous. I may have to paint it with it on the car, but thats worst case scenario because it should be able to come off
Lol never thought this question would be the cause for such a big argument. All i want is to get my strut bar off haha
Sorry for hijacking Martin
If you're still having dificulties and are NOR shoot me a PM and I'll come and help you
yea nice man they stand out red dont they ! , thats why i did mine , but yea looks good man
oh yea btw i dont even remebver u having a strut bar on ur yah34 dealy in the first place did u like all of a sudden put me in ? lol , when we where putting my heat shield in ur car i dont remeber it lol , but yea cutting disc XD , AND NO NOT ON MY BRAKE LINES :D
Edited by Yaah31
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
