Hello All,
I had a billet coil pack cover made up for my CA18 last year and there has been a bit of interest in getting them made up for other engines. My brother has finally had got around to designing them for RB's and SR's and has got a few businesses that have ordered some batches in the last couple weeks, since he is already doing some batches i asked if he would do a cheaper price if i could get enough orders to warrant him making another batch, So here we are.
1 Month time span (14/10/09 > 14/11/09)
10 orders needed
GROWLY CUSTOM BILLET COIL PACK COVERS
CNC Machined from 6mm Billet Aluminium
Supplied with Stainless Screws needed
CNC Machined Finish with a Choice of Engraved Designs,
  • RB 25 COIL COVER :- GROUP BUY = $120; RRP = $160
  • RB 20 COIL COVER :- GROUP BUY = $120; RRP = $160
  • CA 18 COIL COVER :- GROUP BUY = $90; RRP = $120
  • SR 20 COIL COVER :- GROUP BUY = $80; RRP = $110 (non-VTC only)
  • RB26 CENTRE BADGE :- GROUP BUY = $50; RRP = $70 (Pictures up by next week)
Postage & handling $20 Aust'' Wide
ENGRAVINGS :-
  • Choose from the Logo's shown below, or;
  • Custom engraving using a Microsoft Font i.e. Number Plate, e.t.c
ACCOUNT DETAILS
BSB: 124001
Account number: 20470454
Account name: M L Stirling
Bank: Bank of Queensland
Once the payment has been sent through an email MUST be sent to [email protected] with;
  • SAU User Name
  • Address
  • Contact Number
  • Engine Type
  • Design Wanted
My CA Cover;
Edited by D_Stirls
https://www.sau.com.au/forums/topic/291973-coil-pack-covers-rb2025-sr20-ca18/
So nothing for Rb26...
What he is doing for the RB26 is a billet decal that replaces the factory decal in teh centre of the coil pack cover. (pictures will be up in a couple days)
He can do the coil pack covers for an RB26 but not for that price.
For him to make a 26 cover that would suit the cam cover profile (because it's quite raised) you'd be looking at $140 in material cost alone and more that that in machine time .
Edited by D_Stirls
on r33 s1 there's a ignitor at back will this fit back in stock position with these?
how long after group buy finishes we can expect delivery?
Hey Mate,
You'll notice that on the rear of the plate in the first picture that there are 4 holes, these are tapped and are there so the ignitor can be re fitted. As for the date of delivery, they will all be sent within a week of the group buy closing.
Dale
Can I get one without the 4 holes tapped in the rear? As I do not have an igniter pack.
No problem, Just put it in the email that you send after the payment has been sent.
Here is an example of the decal for the centre of the RB26 Coil Pack Cover;
Here is one that was done for a customer of my brothers, it's more complicated than the one being offered in the GB as it has raised lettering was black anodised and then rubbed back; but it gives you an idea of what they will look like fitted.
Edited by D_Stirls
Count me in...
Though I'm holding off on sending the money through until 10 people have confirmed, so I know it will go ahead.
Cheers
same applies to me, count me in and let me know wen u find a 10th and I'll forward an email with wat I want plus the money... Cheers
Ok so this is where we are at;
1. Ryno
2. rhys-
3. 08r3308
4.
5.
6.
7.
8.
9.
10.
awaiting next GB due to cash :thumbsup: is there gonna be another one ???? :s
Not sure, this one is a bit slow to start so it depends how this one goes in the end.
Edited by D_Stirls
Is it possibly he could do the tommy kaira logo??
PM Sent;
1. Ryno
2. rhys-
3. 08r3308
4. gwholxc
5. FIRE BREATHER
6.
7.
8.
9.
10.
Edited by D_Stirls
4 days left, and by the way this GB is going it'll probably be the last.
I have spoken to Matt and whoever has stated that they want one he will do one for even though i didn't get the numbers needed.
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
