got another skyline sitting at my cousins place in Victoria that i need to get back here
its not drivable and all the trucking places said that cause its not drivable it will take 3-4 weeks -_-
name a price or what ever and we can work something out
need to get it here asap before the council go Q_Q
Mitch - you car hire a car trailer for about $70 per day + $20 deposit. If you have a decent car to tow the trailer and able to drive over, spend the night and then drive back you could get your Skyline here for $140 plus fuel. $70 if you were really keen to drive over and back within 24 hours (although I wouldn't recommend this if you don't have someone to take turns at driving).
Just a suggestion.
mitch...
myself and kidafa have his stag with tow bar and a car trailer....
gna b the best part of
3000kms on the car, 1 nights accom, 6 tanks of fuel... food for 2 hungry M/F'ers
name a price n well get days off work rocking :)
mitch...
name a price n well get days off work rocking :D
its only in melb haha , 800kms each way
right now i only have $400 :)
how much do professional car carriers charge?
Being melb, it could be cheaper for you to put it on the back of the train
-D
-D
its not drivable so hardly any of em want to touch it
and the ones that do will take close to a month as its not priority :)
cheapest i found was $278 but that has to be dropped at the depo and picked up from the depo
are you an RAA member?
they do free towing to a certain point :D If not, sign up tomorrow, will cost u $115 for RAA plus, and then head over to melb and call them, make em tow it to the depot, and do the same when it arrives in adelaide
Problem solvered
-D
EDIT - They tow up to 20km in the city and up to 100km in rural areas for RAA Plus. RAA premium gives you 50km in the city, 200km in the boonies
they do free towing to a certain point :) If not, sign up tomorrow, will cost u $115 for RAA plus, and then head over to melb and call them, make em tow it to the depot, and do the same when it arrives in adelaide
Problem solvered
-D
nah im not
When you join on the spot you only get standard benefits for the first call out.
joining up wouldnt benefit me much , already been through this with a mate who works at RAA
nah im not
nah thats when you call them out without being a member and then you pay the dude on the spot for membership
if you call them up on the phone, aka tomorrow, and apply for FULL raa plus/premium membership, you'll get full benefits the first time you call them - which is whenever you can get to melbourne to be honest
get a tow for the car to the depot, and then get the free taxi to the airport/train station, then the next day call RAA again and get another tow - standard benefits are few, but the plus at least gives you unlimited call outs and the towing..
-D
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
